TwinTurbo.NET: Nissan 300ZX forum - There is no difference between high or low boost
Subject There is no difference between high or low boost
Posted by PLEAZURE in CA (SD) on March 21, 2005 at 11:48 PM
  This message has been viewed 48 times.
In Reply To Profec B question....is low boost limited to like 12 PSI?? posted by dilly yo on March 21, 2005 at 08:22 PM
Message It all depends on how you set up ... you can set them up to boost the same, you can set up the high to be lower than the low or low to be lower than the high and so on.. got it !?
I set my low boost to 14 PSI and my high to 16 .. I can increase it for a drag event..
For 14 PSI, I have my boost at 34% and set gain at 130 and the gain at 45%
set gain should be close to you boost (130=13PSI) but not too close, let's say your boost is 14PSI and set gain it at 135, you will spike ..
If you spike lower your set gain and your gain.
Start with gain at zero, find your boost % and your set gain that will give you let's say 14PSI. once you get a steady boost without spiking .. start raising your gain till you get to the max without spiking.
"A nation of sheep will beget a government of wolves."
"It should come as no surprise that the people who own and control the world have put their interests before the greater good of humanity." Henry Makow Ph.D.
PLEAZURE in SD
Matt
91TT Aztec Red stg IV+
